I know they are somewhat different motors but can I put a motor from an 85 S10 into a 90 S10 that had the 2.8?
2.8 from 85 S10 go into a 90 S10?
Yes you can. But you are right they are different. You can keep all your 2.8L fuel injection and put it on the old motor. You will loose a bit of power since the valves in the old heads are smaller.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
You need to keep the flywheel/flexplate on the 85. You cannot use your 90 flywheel/flexplate. You will also need to swap over your accessories, timing cover, oil pan and distributor.
Basically just use the block, heads and internals.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
