removal of accessory belt tensioner
  • cutlass supreme FE3
    • Nov 2008
    • 225
    How do you remove the belt tensioner off a 2.8 MFI?
  • RedogOnyx
    Alero OSV wanna-be
    • Nov 2007
    • 82
    Pics?
    Never seen one, but a pic might help me help you.
    Just did one on my LA1 last weekend in the 20* weather, what fun, but not hard. At least on my car it's held in by one 15mm bolt
      • Nov 2008
      • 225
      on the passenger side there is a tensioner that you need a 3/8 ratchet to loosen to remove the accessory belt off. It is 20 years old and never replaced.
      I see it move up and down quite easily with the motor running. In the past it didn't move as much so now i think it needs to be replaced as it does not keep a good tension.
      • RedogOnyx
        Alero OSV wanna-be
        • Nov 2007
        • 82
        If it's anything like mine there is one bolt thru the center holding it on the block. Loosen the belt and get a socket down there and undo the bolt and take it out
          • Nov 2008
          • 225
          Originally posted by RedogOnyx View Post
          Pics?
          here are some pics
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            talk about a PITA! find the most shallow socked you can and hope its not too long lol. took me a good half an hour on my beretta with the 3400. you may have to switch to a wrench after a few turns
            • Azrael
              Accelerating uphill in OD
              • Apr 2005
              • 763
              You actually have more room to get at it than I do. In the GM service manual for my car you have to raise the front of the car up on stands, remove front passenger wheel, put a jack up to the oil-pan, undo upper engine mount, lower engine with the jack, then access tensioner through passenger-side splash shield.
              The same procedure might work for you. It didn't work in my car though, engine wouldn't lower enough. Silly GM.
              1995 Grand Am SE
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                damn that would suck! i would grind down a socked b4 i did that lol
                  • Nov 2008
                  • 225
                  same here i would done the socket in first.
