found an actual CR calculator
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    incase its usefull to anyone aside me.
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    i like the dynamic compression part. i should figure out what mine is someday lol. always been kinda curious
      • 9191
      That is no different than the one we have on the site, with the exception of the dynamic CR. But, you can ask Ben, there is no real way to accurately calculate the dynamic CR as it is an ever changing variable.
      I actually created a version of the site CR calc that has dynamic CR, but opted not make it permanent.
      Originally posted by SappySE107
      Dynamic compression is not fixed, so I don't buy into those numbers meaning anything. Compression changes based on trapped mass, which changes based on valve events, intake design, exhaust design, and stroke/rod length along with temps and air/fuel mixture quality, etc.
      And the intake closing value for 2 cams can be identical but they can have different opening and overlap values with the exhaust, which changes everything again. Not all cams have symettrical lobes. Some ramp up fast and close slower, and the other way around. I saw no mention of this making a difference to their formula. Dynomation doesn't agree with what they say and it goes against everything I read prior regarding dynamic compression ratio being dynamic, not static. Dynamic compression changes with RPM.
        Live life 3.7mi at a time
        • 4555
        The calcs don't match the site.
        3.622" bore
        3.307" stroke
        8cc dish pistons
        .06" head gaskets with 3.8" bore
        32.4cc head chambers
        .01" above deck
        Should be about 11.56:1, that site says 12.2:1 (Ban built a DOHC flat top piston and 3500 head combo) that was 12.6:1...what one is correct?
          • 4555
          Here's the closest one I found (just have to convert cc's to ci's or vice-versa).
          Either way, it's spot on with the site, but I have calculated 11.56:1
