Removig the EFI from a 3.1, have the carb and manifold from a 2.8. had run the EFI fuel line with an external electric fuel pump, can I now use these lines for the carb with some king of pressure reducer? Engine is in a 47 Chevy. Have the EFI and complete wiring harness for the 3.1 91 Camaro, and I don't need it!
3.1 to carb
The 3.1l's have diiferent intake port positions than the old carb iron heads. So if you want to use a carb you have to use 2.8l iron head heads to use a carb or custom make a manifold. I asked the same question a couple of days ago. See thread "Head swap, please help" under Pushrod Performance to see what I mean
-Gary-Gary
1983 Camaro 2.8l not much done yet
1999 Chevy Prizm - typical bolt-ons
All RWD iron head 2.8 3.1 and 3.4 heads are interchangable. The older 2.8's pre 85 had smaller valves. The alumium heads uses a different intake. The efi fuel lines will work you can use a fuel pressure regulator to decrease the pressure from the electric fuel pump. But advance or auto zone sells a inline electric fuel pump which may be cheaper than buying a regulator and it wont have to have the regulator.Last edited by 923.4v6; 03-15-2009, 05:20 PM.
That I did not know, very sorry
-Gary-Gary
If you do not have a return line you cannot use the stock pump. If you do have a return line just get a return style regulator for carb applications and set your pressure and your good to go. You can never run a pump without a regulator, weather it be integrated into the pump or external.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
