oil temp gauge: need help
  • extremeskiier728
    • Mar 2004
    • 42
    im trying to install a oil temp. gauge and it says in the instructions about tapping into the oil temp. warning sensor. where is that if there is one or how do i go about hooking this damn gauge up. application is a 95 Nbody 3100.
  • extremeskiier728
    • Mar 2004
    • 42
    help would be greatly appreciated
      • 9191
      Why get an oil temp gauge anyway? And these cars don't have a oil temp warning sensor, so you can't tap into it.
      • extremeskiier728
        • Mar 2004
        • 42
        ok so does anyone know how to hook this crap up.
          • 9191
          From the Autometer site:
          2. Install temperature sender.
          A. Water Temp: Install temperature sender ( included.)
          B. Oil & Trans. Temp: Hole may have to be drilled and adaptor nut
          (included) welded or brazed in pan.
          Be sure there is adequate
          internal clearance for nut and sender. Sender should
          automatically be grounded when installed. If not, proper ground
          connections should be made.
          Looks to me like you need the sending unit. But once again I ask, why an oil temp gauge?
          • extremeskiier728
            • Mar 2004
            • 42
            cuz i got with a dual gauge pod and i dont have time to sell or money to buy somthing else and i want something in that dual pod other than just air:fuel
            • extremeskiier728
              • Mar 2004
              • 42
              plus im workin on a remote filter and oil cooler so id like to see if it makes a diff.
                • 9191
                Hmm... ok. Well, if your gauge didn't come with a sending unit, then it looks like you'll have to shell out some $$ (between $15-28+ shipping from what I've seen) to get a sender before it will work for you.
