3500 a/c delete
  • gar70614
    • Oct 2008
    • 330
    3500 a/c delete
    does any one know it a a/c delete made for a 3400 will fit a 3500? i cant use the idler pully like superdave because my motor mount bolts there.
    http://cgi.ebay.com/ebaymotors/02-03...Q5fAccessories
  • gar70614
    • Oct 2008
    • 330
    nobody?
    • PCGUY112887
      • Feb 2006
      • 1067
      What if you just got a shorter belt?
      SpudFiles
      Theopia
      Enjoy life online.
      • gar70614
        • Oct 2008
        • 330
        ur sayin go from the crank pulley right to the water pump? i think it will hit the motor mount. pcguy did ur 3100 compressor bolt up i was skiming the sticky and didnt see
        • hookdonspeed
          • Jun 2007
          • 322
          shorter belt wont work, ive been looking at my 3500 and wondering if ima use AC or not..
          • PCGUY112887
            • Feb 2006
            • 1067
            Yes, my 3100 compressor works... minus 1 bolt (bottom bolt). The mounting hole doesn't align but I am at least the second person to leave it off and be fine.
            SpudFiles
            Theopia
            Enjoy life online.
            • gar70614
              • Oct 2008
              • 330
              so if that a/c delete bolts in the same places as the compressor it should work. any one know if it does?
              • hookdonspeed
                • Jun 2007
                • 322
                ill check at work to see if we have one for a 3400 instock, if we do ill see if itll boltup to my block... (3500) ill post tomorrow on what i findout
                • hookdonspeed
                  • Jun 2007
                  • 322
                  sorry, we dont stock the gm ac bypass :/
                  • gar70614
                    • Oct 2008
                    • 330
                    it would be no big deal if i could get one at a autoparts store then just return it but i think its special order and they dont take returns on special orders.
                    • hookdonspeed
                      • Jun 2007
                      • 322
                      just start calling around, im sure one of the smaller-non-chain stores might stock it...
                      • gar70614
                        • Oct 2008
                        • 330
                        auzone has one in stock a couple towns over im a try to pick it up today and check.
                        • hookdonspeed
                          • Jun 2007
                          • 322
                          i just ordered one from dorman, its cheaper then a AC compressor, ill let you know what i find when it comes in.
                          • gar70614
                            • Oct 2008
                            • 330
                            i got one from autozone it fits but had to cut the bracket a lil and the pan a lil but it works.
