Heated O2 Sensor Update
  • Scott_68B
    • Nov 2003
    • 147
    I'm going to be updating my O2 sensor from the standard OBD1 unit to a heated unit. If I specify 95/95 Lumina will I be ok? Also, is oxygensensors.com the cheapest way to go?
    Thanks!
    -- Scott
  • jmgtp
    • 1219
    I don't know what a 95 lumina uses but I went with a 3 wire sensor off a chevy van. Got it at AutoZone for pretty cheap and the 3 wire simplifies things a bit.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
    • americasfuture2k
      • May 2008
      • 146
      how much did you pay for the 3 wire? and which van was it?
      ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
      87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
