on my 3500 upper next to the throttle body there is a tear drop shaped place with one hole with machine threads and a larger holethat conects to the neck of the mani> wat bolts there? is it something that had to do with the fly by wire or is it something else. there wasnt anything there wen i got the motor so need to know wat goes there or if i should just plug it. thanx
3500 upper? iac or wat
The charcoal cannister purge valve was located there. You can plug it or use it for a vacuum source.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
Yup evap purge solenoid. IAC is controlled directly with the electronic TB. Cruise, IAC, and throttle all in one with the electronic TB. 1/4" NPT tap if you want to use a vacuum barb...sigpic
