Harmonic Balancer Installation
  • Canyonero
    Plays with Volvos now.
    • Sep 2006
    • 1112
    Manual says I need a special tool. Is this true, or is this a case where a block of wood + hammer will suffice? Ok, maybe that isn't a good method, but what are acceptable ways to install it?
    Thanks
    balancer onto the crank shaft?
    ........ i'm really not sure.
    • Canyonero
      • Sep 2006
      • 1112
      Yes, balancer to the crankshaft. Far as I know they're all the same, but the engine I'm working on is a 3.4L (iron head). Engine has a 3.1 intake, installed in an Isuzu Trooper (not that it matters).
      Those huge 3.4 brackets will be going away once I source a set of 3.1 brackets.
        • 9191
        Don't hammer it on, as damage to the crank and/or bearings can occur. You should be able to place the balancer on, insert the bolt, and move it to its final position by tightening down on the bolt.
        • geldartb
          The Situation
          • May 2004
          • 1994
          i used a longer bolt to get it on the crank far enough so the stock(normally used bolt) would fit and then tighten it down with that.
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
          • Canyonero
            • Sep 2006
            • 1112
            I didn't think that bolt was long enough, but apparently it is. I have it cranked down as far as it will go, hope that does the trick. Now I can't find a belt that fits, which is odd because I took one off when I started the project...
            • geoffinbc
              Iron Head Enthusiast
              • 5831
              I always avoid using the bolt. In some cases the balancer has less interference than others, and the bolt will work and wont strip out. However the tool is cheep and universal for all motors plus its a puller and an installer so the tool is a great investment. A block of wood and a hammer should only be use for that initial seating of the balancer but don't sit there and smack is all the way home.
              • Canyonero
                • Sep 2006
                • 1112
                I popped it with a rubber mallet a couple times is all, then took it in with the bolt. I put a little oil on the threads to cut the resistance there.
