97 3400 transport
  • hookdonspeed
    • Jun 2007
    • 322
    97 3400 transport
    what size injectors did they use, and at what fuel pressure?
    i went to the yard today,it was the only 3400 they had
    pressure should be 43.5PSI.... i think they didn't go to like 55psi until 2000?
    flow..... 19lb/hr minimum
    • hookdonspeed
      • Jun 2007
      • 322
      i have a newer FPR i can put in, what LB/hr would that make them at 55psi?
      edit: i need to know if these can be made to work for a 3500 engine, or if i should buy new injectors?
      • geldartb
        The Situation
        • May 2004
        • 1994
        here you go all your injector info needs.
        it would make them 22psi which is what the 2000+ ones are.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
        • hookdonspeed
          • Jun 2007
          • 322
          is that enough for a 3500 or should i upgrade them?
            should be, assuming you don't go absolutely nuts with it. stock, fine
            • mr.rogers
              • Sep 2007
              • 40
              are the 2000 + injectors better quality? the one i had from a 99 were big and ugly, i got a new rail and injectors from an 01 ga the other day and they look completely different.
                they are different, but better quality? i don't know about that, they're newer, and designed for higher pressure, if that means anything for you. i believe they use different connectors for electrical as well...
                • hookdonspeed
                  • Jun 2007
                  • 322
                  im staying stock for now, im turboing next summer, but i was planing on a new set of injectors when that time comes.
