fpr pressure 95-99
  • gar70614
    • Oct 2008
    • 330
    fpr pressure 95-99
    on my 3500 i have 99 3400 injectors but im unsure if i have to correct fpr. i know 2000+ have a diff prssure but i have a fpr from a 95 3100 is that the correct pressure for my 99 injectors? i just cant track down the numbers for wat years have wat psi's. thanx
  • geldartb
    The Situation
    • May 2004
    • 1994
    43.5 for 99
    55 psi for 00+
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • gar70614
      • Oct 2008
      • 330
      u know wat psi a 95 3100 would be?
        43.5 is for '99 and older. 55 is for '00+
        I'd use the 00+ FPR, you'll need all the fuel you can get for the 3500. 3500's came stock with 24lb/hr. with 22.5 3400 injectors you are already getting close to their limit.
        • sprucegagt
          Old School KI
          • May 2005
          • 703
          Actually the '99 3400 injectors are 19 lb/hr @ 43.5 PSI.
          Your local OBDII moderator
          2000 Grand Am GT w/ WOT parts
            Correct, but they are 22.5 @ 55 PSI
            • gar70614
              • Oct 2008
              • 330
              so i can use a 2000+ fpr with the 99 injectors?
              • sprucegagt
                Old School KI
                • May 2005
                • 703
                Yes.
                • gar70614
                  • Oct 2008
                  • 330
                  k thanx guys
