New Member Fuel O-Ring Problem
  • jmgenesee
    • Jul 2009
    • 5
    Hi,
    Brand new to the site today. Looks awesome!
    Just finished a LIM job on my 2003 Buick 3.1 Turned the key and had a fuel leak. Off with the plenum. Found the inlet fuel line at the rail was blowing out gas. Dis-connected and found no o-ring. I did undo the lines when removing the rails. I didn't see anything in the rail. (I may be wrong on that.)
    Put on a small injector o-ring, re-connected and no more leaks.
    Should I be looking for the "right" o-ring and if so, where do I find one?
    BTW, I hate connecting the small hoses to the heater pipe! Thanks for the help to a 68 year old GM car guy!
    John
    • 9191
    I am pretty sure the rail o-rings are the same as the injector o-rings, so you should be good to go.
    Welcome to the site!
    • jmgenesee
      • Jul 2009
      • 5
      Went to CarQuest today and found a package of assorted Viaton o-rings under the
      "HELP" brand. Will dis-connect and size 1 of those up with my "temp" injector o-ring.
      Thanks,
      John
      • jmgenesee
        • Jul 2009
        • 5
        Buick O-Ring Saga Continues
        Pulled my temp o-ring yesterday to replace with a new Viaton part
        and there was nothing on the collar when the line pulled out.
        Now, I'm not crazy as I didn't remember seeing 1 the 1st time.
        I have the wiring for the rail dis-connected except for the
        switch down below the power steering unit. (Oil pressure?)
        I looked in the rail and on top of the transmission and can't see my missing 2 o-rings. What gives? Did these 2 rings disappear into thin air?
        Thanks,
        John
          • 9191
          Did you look inside the rail or even under the car?
          • jmgenesee
            • Jul 2009
            • 5
            Ha! Spent some time this morning and found 1 way down below the transmission.
            I suspect the 1st one is somewhere down there too. The fuel rail is clear.
            Even took a Shop Vac to it. Now, get it back together and go back to my
            '65 Chevelle! Will let you all know how it runs.
            Thanks again for all the advice!
            John
