Timing Chain and Gas Mileage
  • PCGUY112887
    • Feb 2006
    • 1067
    A few months ago I upgraded my 3500 to the 99 timing set (sprockets, guide, and chain). Everything went great, but I noticed that after my MPG's fell a lot, about 5MPG. I figured it was just due to having the battery unplugged and having to relearn the trims. I can get just over 200 miles per tank when before I was hitting almost 300. I've tested and tested when I filled up and my gas mileage STILL hasn't returned! I plan on installing a new intake pipe and new MAF along with a cone filter, so I know I am going to be retuning again soon and hopefully bring back my MPG's, but what the hell happened to them from just changing my chain?
    SpudFiles
    Theopia
    Enjoy life online.
    Chain is a little bulkier, but I can't see it changing it that much unless you are off a tooth or something on the timing.
      Did you mess up the timing one tooth??? That's the only thing I can think of...
        vote #3 for cam timing issues...
        a timing set alone won't cause issues like this...
        • PCGUY112887
          • Feb 2006
          • 1067
          I made sure a number of times that it was absolutely perfect, I took enough care to not turn anything as well to keep the timing dead on. That is the first thing I thought of
          SpudFiles
          Theopia
          Enjoy life online.
          • asylummotorsports
            Banned
            • Oct 2005
            • 649
            Deleted!
            Did I actually write that?
            Need a better brand of stupid pills. Sorry!
            Last edited by asylummotorsports; 11-10-2009, 09:36 AM. Reason: Not thinking on my part
              • 9183
              Do you screw up the setting of your external trigger sensor when you removed the cover? That could cause your timing to be off as well.
              • PCGUY112887
                • Feb 2006
                • 1067
                That's a good idea, I will check it out!
                SpudFiles
                Theopia
                Enjoy life online.
                  Have you had any more metal shavings in the oil? What was the cause of that? Did you ever figure that out?
