I assume too often, so I thought I should ask. Is there much, if any, weight difference in a '82 2.8 ironhead and a 3.4 ironhead? Thanks
Weight Difference 2.8 and 3.4
Nope, maybe a few lbs but nothing major.
Agreed the 3.4L would be slightly heavier due to a bit more material required to make the cylinder bores the longer throws on the crank and the larger diameter pistons. But it bet it would be under 10lbs1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
