Dropping Subframe
  • eckoxl
    • Jul 2009
    • 230
    Dropping Subframe
    What are the steps on dropping a '99 grand am subframe? And what should I go ahead and replace on the subframe while its out?
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    I would replace any bushings on it. Subframe to body bushings, control arm bushings, swaybar bushings, ect. As for instructions on how to do it, never done it on an N body.
    • RedZMonte
      • Feb 2004
      • 1378
      on my W body's you need to have a engine support (sits on fender lips and holds engine up.. then remove the lower motor mounts and cooler line and remove the sub frame bolts.. the subframe is 2 seporate pieces on the GA's iirc where as the W-body is 1. but same process.
      like this one... I built one that worked for doing my tranny out of steel.
      check the bushings, replace if damaged, also check motor mounts and repalce if damaged (most likely have a fluid filled that may be leaking goop). If the sub frame bolts are stripped or bent also replace them..
      S
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
      • RedZMonte
        • Feb 2004
        • 1378
        Kinda looks like this installed.
        Shane "RedZMonte"
          • 9189
          Nice brace! You could always go the redneck method and just use a 4x4 and some chain. Not the prettiest way, but it works.
          • AleroB888
            • Nov 2009
            • 249
            The subframe is out of mine right now, without a support. In fact, the front mount is also removed....
            • AleroB888
              • Nov 2009
              • 249
              That actually works better, if the hood had to be closed enough not to hit anything above it when the car is raised.
                I used a 4x4 wrapped with some chain to swap auto trannies in the 91 way back in the day. It does work shockingly well when you use shorter 4x4 chunks to hold it up off of the fenders. Also I bought one of these things at Harbor Freight fairly cheap:
                $60 takes it home...
                http://www.harborfreight.com/cpi/cta...emnumber=96524
                • eckoxl
                  • Jul 2009
                  • 230
                  Well Im taking the engine and transmission out so would I want to support it? Wouldnt i want to lift the car?
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    unless you have a car lift to lift the car stright up, it will be a PITA, i remember when i ripped out the the Q4 in my beretta with just a cherry picker, it was still a pain. I've never pulled both engine and trans out of a n body, but if i did, i would pull the tranny out the side/bottom with the one sub frame out, then the motor through the top with a picker. you dont even have to lift the car high to pull the tranny out. a 18" jack and jack stands will suffice.
                    like i said, unless i had a hoist, i would never do this again.
                      Grand am's don't have "two subframes" IIRC they have a carriage like the W-body's
                      I could be wrong though.. I Just remember my mom's having that over the beretta dual rails.
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        now that you mentioned it, you are correct. that engine stand setup would be handy in this application.
                          Live life 3.7mi at a time
                          • 4555
                          HAHA, that looks familiar...
                            • 9189
                            Except yours isn't at as bad of an angle due to the rear wheels being up on ramps.
                            • bob442
                              Show Me Your KITS!
                              • Nov 2008
                              • 1305
                              Thats a good idea! but FWD's are still harder to pull out that way with out a hoiste, possible, but much easier.
