Engine weight comparison? any sites?
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    I am searching for some info to find the weight differences between GM engines.
    I would like to estimate as close as possible what my new GVWR would be since I took out the 2.4 and swapped in the 3500?
    Any Ideas?
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
  • Weatheralls Auto
    • Dec 2009
    • 536
    Current on the door placard is 3694 Lbs
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      That would have to be fully loaded down to the hilt max weight. Otherwise your Cavy would weigh more than either of my cars. You should go by the curb weight, which is pretty much the car only weight, full fluids and with no luggage or dead bodies in the trunk, ect. According to wiki:
      Curb weight
      Base 2,562 lb (1,162 kg) - 2,784 lb (1,263 kg)
      Z24 2,749 lb (1,247 kg)
      • Weatheralls Auto
        • Dec 2009
        • 536
        ahh maybe thats why PSMSCAN was so inaccurate when I tried 3850lbs and a run in second gear lol
        I know its not accurate, but thought it would be closer haha.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
          Wouldn't that be nice, lol. Is that supposed to be estimated WHP or at the crank?
          • Weatheralls Auto
            • Dec 2009
            • 536
            How much weight difference you think from 2.4 to 3500, 1 or 2 hundred pounds?
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • Weatheralls Auto
              • Dec 2009
              • 536
              It really doesnt say.
              I am messing with it to see if it sees changes with my tuning.
              Though not accurate, I am hoping to see if my tune is better or worse between changes.
              I have a dyno day coming up, but its not really for tuning, only 2 runs and no time in between
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
                • 9190
                A 3500 weighs 340lbs (http://60degreev6.com/forum/showthre...l-LX9-Weigh-in)
                I doubt the 2.4 is that much lighter than it, and definitely not more than 100lbs.
                  I was hoping that wiki or ebay motors could provide some sort of wieght or shipping weight at least, but I couldn't find anything.
