Small journal identification?
  • sureshot007
    Driver
    • May 2010
    • 19
    I just picked up a 2.8 off craigslist - is there any way I can tell if it's small journal without actually tearing it down and measuring?
    http://www.TeamHazardRally.com
  • dskopek
    • Jul 2009
    • 124
    Do you know the year of the engine? Motors made after midyear 1985 all have the larger journals. If you remove the oil pan look at the crank casting#
    #504 is a small journal crank
    #209,#817,#481, and #526 are all large journal cranks
    Not sure on some of the other crank casting numbers if they are large or small.
    If the crank is a internally balanced crank( has a disk in the middle of the crank for a distributor less ignition system it will be a large journal crank)
    • sureshot007
      Driver
      • May 2010
      • 19
      I'll have to pop off the oil pan and take a look. I found it on craigslist in the next town over. $80 for complete motor and uncut wiring harness from a camaro - how could I say no?
      Thanks again, Dave!
      • dskopek
        • Jul 2009
        • 124
        You can't!!!! just the brackets,mounts, and misc on the motor will be worth that and more to you. Plus it is a RWD setup that you are going to run anyhow.
