91 3.1L Baretta engine into a 96 Baretta???
  • GMartuch
    • Aug 2010
    • 1
    I have a 96 Baretta with a 3.1L Automatic that need a new engine. I have a 91 Baretta 3.1L auto with just 20,000 miles on it. Can I swap the 91 engine and trans in to the 96??? I would like to take the whole powertrain, harness and controller. I am not sure if it can be done. Any Ideas?? What is the best way to do this?
    Thanks!!!
  • 3400beretta
    Banned
    • Jul 2005
    • 171
    *Beretta.
    Yes it could be done.. but it would require quite some work, and you are going ass-backwards. The mount setup is totally different in the 91 vs your 96. Save yourself the headache and buy a 3100/3400/3500 from the junkyard. They can be had for $400-500 with low miles if you look. www.car-part.com www.3400swap.com
      It's illegal to begin with.. that alone should stop you from doing it.
      • mickaz
        • Aug 2004
        • 350
        buy a 3400 its worth close to nothing around here. and you will have a lot more power will having better fuel economy
        Mike 60degree addict.
        • RocketFast321
          • Aug 2006
          • 4
          illegal?
          EveryDay: 2001 Alero 2.4 5-speed
          Hualer, Mpg? ROFL: 1984 Buick Electra Estate Wagon Fresh 3oh7 268h camming. OEM 84 2004r
            • 9189
            Installing an older engine in a newer vehicle is illegal.
