3400 2nd Alternator
  • Khipset
    • Oct 2008
    • 52
    3400 2nd Alternator
    Has anyone added a second alternator to their 3x00?
  • Rhedalert
    Dr. Feelgood
    • 1574
    Nope. I'd like to think it'd be easier to retrofit a 130-145 Amp alternator from a 3400 equipped minivan!
    Brian
    3400 SFI V6, 4T60e
    • Khipset
      • Oct 2008
      • 52
      I'm already running one from a Venture - 125A. Stock in my Impala was a 105A
      What Van has the 145Amp?
      Still doesn't solve my problem though. I'm needing 97 Available Amps (1400W/14.5) for just the Audio equipment.
      I have a 200A HO Alternator, but I have to Rev about 4,000RPM before I see them. At idle it also only puts out about 12.5V - Seems to be rather shitty. But I have not found any other alternatives other than stock replacements.
      I'm just trying to think of a placement... I'll do damn near what ever it takes... I want my Audio.
      Edit: Short of having a custom alternator wound....
        • 9191
        Add more batteries instead.
          but then you put more load on the alternator when it has to charge them back up.
          If you can find the space for a 2nd alternator just make some brackets and mount it up, people do it all the time. There should be a way to trick it into "1 wire mode".. sometimes the newer ones need to have a small load across 2 of the control terminals, i've seen people use light bulbs and resistors for that.
          for your HO alternator, does it have the stock sized pulley? I think it was MRZ that makes a smaller one that would help it spin up a little faster.
