ICM wiring
  • 90z24xr
    • Feb 2004
    • 2
    ICM wiring
    OK, I have a 98 3400 in a Trans sport. Putting it back together and I can't seem to find one of the plugs for the ICM. I have the 2-wire opposite the 4-wire, and the 4-wire connected, but I'm missing the 2-wire that is on the same side as the 4. Which loom does this plug come out of? A picture is worth 1K words in this case!!
    TIA!!
    Rhett
    90 Z24 Cavalier
    3.1L 5spd
  • CNCguy
    Bisong eater :P
    • 1017
    The wire from the CPS connects there. The CPS is located on the rear of the block just above the oil pan. The wires run from the CPS to the ICM and are yellow & purple with a plastic cover.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
    • 90z24xr
      • Feb 2004
      • 2
      Thanks!! I got it to fire now, but need to get the wire on right. I got the banks mixed up I think. Damn it!!
      Rhett
      90 Z24 Cavalier
      3.1L 5spd
        • 9190
        If you followed the numbering on the lower intake manifold, then you have it backwards. Passenger rear is 1, passenger front is 2.
