injector order?
  • gar70614
    • Oct 2008
    • 330
    injector order?
    r the injectors in the same order as the cylinders? my injector harness is numbered 1-6 but the numbers dont match the cylinders. there backwards. like injector 1 is at cylinder 2. is this right or are they suposed to match?
    • 9190
    Are you looking at the numbers on the lower manifold? If so, then they appear backwards. But if you follow the ports, then you see that even though the number is above the wrong cylinder (2 is above 1, etc), the port it is on actually goes to the correct cylinder.
