3500 upper dogbone mount
  • LZeppelin513
    • 225
    I am putting a 3500 into my fiero and am deciding if i want to low mount the alternator and put a dogbone high like the factory fiero set-up, or if i want to leave alternator alone and make a low engine mount.
    My main concern is that the high dogbone would only be bolted to the aluminum head. I am also planning on boosting later down the road.
    Could the added stress on the aluminum head make for a head gasket eating engine?
    Thanks,
    Blake
    • 9191
    Get a dogbone bracket from a W-body or a van or SUV (Rendezvous, for example). It is super heavy duty, and bolts to the side of the head as well as on the block.
    • LZeppelin513
      • 225
      I saw those in a yard and was considering them. The passanger side mount bolts to head and block, but driver only bolts to head.
      I was steering away from this though because it looks like it wound interfere with the stock 3500 manifolds or a set of headers, but I could probably mod it to work. Also, I would think that it would still be applying a fair amount of force to the aluminum head... But idk...just speculating.
      Thanks for the recomendation.
      Any other thoughts
      • LZeppelin513
        • 225
        Does anyone know if the passenger dogbone would bolt up to the aft facing side of the motor?
