L82 being replaced with an LG8
  • 95Lumina3.1SS
    Stephen Martin
    • Mar 2010
    • 28
    I have recently discovered that my cam broke in my 1995 3100 L82. I am about to purchase an LG8 3100. (2000+). My question is as long as I have my original engine, as well as that engine I should be fine shouldn't I? granted my car is OBD1 but that's all computer stuff, I just need to make sure this bad boy will work!
    1995 Chevrolet Lumina LS 3.1 SFI V6
    1996 Chevrolet Monte Carlo LS 3.1 SFI V6
    1999 Ford Expedition XLT 5.4 V8
    2008 Ford F150 XLT Supercrew 4.6L V8
    • 9189
    You will run into issues with the EGR, but that is the only thing I can think of off the top of my head. But, I think I have mentioned this before, look over the 3400 swap guide (http://www.3x00swap.com/index.php?page=downloads), as it will cover any questions you may have.
    • 95Lumina3.1SS
      Stephen Martin
      • Mar 2010
      • 28
      I think you did as well. I couldn't remember though. I do appreciate you (and the other guys as well) consistently coming through will all the info I need. You guys have made this so much easier!
        • 9189
        That's what we are here for.
        • 95Lumina3.1SS
          Stephen Martin
          • Mar 2010
          • 28
          damn dude this guide is freaking rediculous! (in a great way). This should guide me through the whole process. I had been wondering about the MAF and didn't figure I'd need to use the LG8 MAF...just use mine. Question answered! this is sick dude.
            • 9189
            Hence the reason I told you to use it. It really is the best resource for that swap available on the internet.
            • siKKa
              LVS2XLR8
              • Sep 2008
              • 30
              why not LA1? (3400) its bolt up and plug and play, may have to swap timing covers but you may have to do that anyway. helpful hint, the old school 3.1 mpfi egr (same as your 95 3100 egr) can be made to work on certain 3x00 manifolds...
              1994 Cavalier Z24, 5 speed swap, 3500 LX9 (summer ride)
              1998 Lumina LS, (SS) L67 3800 S/C swap (winter ride)
              1999 Honda CBR600 F4, 600cc DOHC I4, cammed.
              • bob442
                Show Me Your KITS!
                • Nov 2008
                • 1305
                i think thats a 99 manifold your talkin about. theres a swap bracket for that though on the wottech store non the less. yeah, i think you might have to swap injectors and a computer chip for the 3400 to run to its full potential. if your after power gains.
                • 95Lumina3.1SS
                  Stephen Martin
                  • Mar 2010
                  • 28
                  I would love a L67 but I can't find good prices with as low of miles as I have found. 300.00 for 75K is killer, plus the car needs to be back on the road again. I mean the predicament im in is why I don't search. Driving my '08 F150 everyday is killing me in gas, i need the Lumina mobile ASAP.
                  • 95Lumina3.1SS
                    Stephen Martin
                    • Mar 2010
                    • 28
                    Got a question for you guys, I have put a little extra thought into things, I went online to northernautoparts and they sell engine kits. They have a complete 3.1 M code kit that includes, Chevy 3.1M 1994-1996
                    Master Kit Includes:
                    Stock style Camshaft
                    Stock style Lifters
                    Stock style Timing set
                    Stock style Pistons
                    Stock style Piston Rings
                    Stock style Rod Bearings
                    Stock style Main Bearings
                    Stock style Cam Bearings
                    Stock style Oil Pump
                    Stock style Frost Plugs
                    Stock style Gasket Set
                    This kit costs: $678.00. They also sell a cam kit which includes the cam, lifters, and timing set for $274.99. Should I go this route or should I still just buy another engine? I need some advice here, I mean that Master Kit pretty mich seems to rebuild the engine, i however don't need an oil pump now, because I just bought that new melling oil pump. Also they sell cams by melling and clevite. Which one is better (if the advice is to rebuild)
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      just swap in any 3100 sfi or 3400 sfi and be done with it, if you have the stock motor for swap parts you'll be fine, you might spend 4 hours swapping parts (this includes getting gaskets and beer and pizza) and you can throw any wrecker motor in. from 95-2005 your only worries are upper and lower intake manifolds, i'll assume its got a thread in and quick clip heater core line for the lower intake, so you can get the 14x1.5mm tap (i think it is) and thread the newer intake and go to town, change the fuel injector harness from your motor to the new one, and heck, just leave the EGR unpluged till you get a swap bracket
                      if not it will just cause a harmless check engine light and better fuel economy. worst case senario on the motor swaps you'll have to swap the timing cover which should take 20 minutes.
                      You can rebuild the motor but its not cost effective as these motors are abundant. kinda why all of us guys are here.
                      Bob
                      • 95Lumina3.1SS
                        Stephen Martin
                        • Mar 2010
                        • 28
                        Hey Bob, I had a question though, I know we've pretty much decided that a 3.1/3.4 is the easiest to do. BUT...a local guy is selling a low mileage 3.8 super cheap. it's just the naturally aspirated L36 engine. I know some older 3.8's can use the 4t60...can I use that? Because as cheap as this engine is, I could just buy a harness and ecm too. Local yard has an abundance of these. I mean my ONLY issue is that I just bought motor mounts and transmission mount for my 3.1 :/ I just wondered if this was an option. I just got crapped on by this dude who i was going to buy the LG8 from...maybe he'll pull through.
