Air/fuel/volt meter install?
  • impala2001
    • Apr 2011
    • 6
    I've never installed one picked one up cheap and really wanted the "volt" meter so i figured ill hook up both but i need some help:
    1. what wires are for what?
    2. where do i tap into to get the air/fuel?
    3. where is the best spot to hook up th volt meter part?
    this is all on a 2001 impala 3400
    thanks in advance for your help!!!!
  • Jonpro03
    • 362
    For the volt meter, tap any pink/blk wire you find in the car. You'll likely find it under the dash on the driver side.
    Is the air fuel a narrowband?
      sounds like you have the base cluster.
      there is a purple wire that connects to pin A8 on the instrument cluster, that's a +12V wire that gets switched on with the key(and actually supplies power for the cluster), and should be a good source for a voltage reading. it is fused by the PCM/BCM/Cluster fuse as shown here.
      • impala2001
        • Apr 2011
        • 6
        Nice thanks! as for if its a narrowband how would i tell?
        • impala2001
          • Apr 2011
          • 6
          K so I got that its a narrowband.... and this is the instructions i dug up (if anybody else has the same Q's):
          Thanks for your help!
