wideband o2
  • Rootie524
    • Feb 2010
    • 543
    wideband o2
    got a wideband o2. which o2 sensor do i want to replace with the wideband.
    the upstream or the downstream. im pretty sure you want to do this to the downstream one, but im just double checking.
  • mickaz
    • Aug 2004
    • 350
    you don't replace either. you put a new o2 bung NEAR the first 02
    Mike 60degree addict.
    • boomofdoom88
      • Oct 2010
      • 111
      This was a question for me as well. I was under the assumption you could wire in a wideband in place of one of the stock narrow band to be able to use it with HPTuners and other tuners? Guess I read the wideband instructions from wot-tech wrong?
      • Jonpro03
        • 362
        An Innovate LC-1 WBO2 has a narrowband output that can replace the front o2
        • boomofdoom88
          • Oct 2010
          • 111
          Thank you very much! I looked over the instructions again and saw that.
