Does anyone know when the 3.9L vvt engine switched to the new bolt pattern? Which cars and years were which bolt patterns used in?
3.9 bell housings
there's more than one bellhousing pattern for the 3.9?
just find one that's attached to either a F40 or a 4T65, those use the classic "gm small metric" stuff.
Originally posted by NateD4 View PostWhat would be on a 2007 G6 MU9?
I am looking at hooking it to a 2010 3.9 from an impala (LZG engine).
Thanks
NateIn other words, get an F40 from a 3.9 car and it WILL have the correct pattern for your 3.9.Originally posted by robertisaar View Postthe F40 has multiple patterns(depending on the engine it is hooked up to), the 3.9 does not.-60v6's 2nd Jon M.
i've never seen a FWD impala that didn't use a 4T65. all of those use the same "gm small metric" pattern that go all the way back to the earliest 2.8s at least.
It is that easy, you're making it hard. There is one bolt pattern for the GM 3900 V6 no matter what GM car it is from. The only Domestic U.S. GM car that came with an F40 is the 2006-2007 Pontiac G6, no exception. No matter what car the 3900 is from that transmission will bolt to it.Originally posted by NateD4 View PostNot quite that easy. The trans I'm looking at is already out of the car.
I also want to use a 3.9 with active fuel management.
The only car that has it is the impala and I'm not sure what bell housing it has since it hooked to an auto.
Now what you're going to do about a DOD (AFM) engine bolted to an F40 I don't know, as DOD was not used with the F40 and unless provisions have been found to tune out the BCM/TCM input the PCM will be looking for from the auto trans the PCM will set codes that will affect driveability.
a couple of Saabs used it as well, but they ran Ecotecs which DO have a different bellhousing pattern. so, if it came from an Ecotec car, don't bother with it. if it came from a 3.9 car, you can use it.
