3.4 s10 project
  • 3400s10nos
    • Sep 2011
    • 8
    3.4 s10 project
    im going to be mounting a 3.4 out of a 94 camaro in a 1993 s10 ... has n e one been able to use a front wheel drive block in a rear wheel application....the problem i see is the starter is on the wrong side and it doesn't look like i can mount it on the opposite side of the fwd block .....my concern is i bought a 3400 from a friend that has diamond pistons that are .060 over and i don't want to have to machine my 3.4 block for .060 if i can avoid it
    any wisdom would be great..
    thank you
    • 9191
    Welcome to the site!
    There are plenty of people using FWD blocks in RWD vehicles. Do you have an auto or manual tranny? With an auto (700R4), I don't think there is really much you need to do. With a manual, you will need to find a 2-pocket bellhousing to swap onto your tranny.
    • 3400s10nos
      • Sep 2011
      • 8
      im going to be using a manual trans . i have a borg t5 any ideas where i might find that bell housing .....im glad to be on here ...that acronym kinda kicked my ass lol.....i was thinking complicated
        • 9191
        Here you go... http://60degreev6.com/forum/showthre...D-Bellhousings
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          As far as I know a bellhousing from a 2.2L with a manual trans will work as well.
            Live life 3.7mi at a time
            • 4555
            The oil pan to frame clearance is the biggest obstacle with the FWD engine.
            • 3400s10nos
              • Sep 2011
              • 8
              that was one of the other questions i had .... i can use a 2.8 oil pan but the 3400 that i have has the bolts that go through the side of the oil pan .....will the 2.8 oil pan fit over those caps or will i have to use different main caps.....cuz if i have to re-do a line bore on that block i may as well use the 3.4 rwd block and have it punched out to .060 over
                In a 3rd gen Fbody you can cut a notch out of the K member to get the stock aluminum pan to clear, not sure in a S10 though... you could always notch the oil pan as well, it would be pretty cheap to have a shop weld in some aluminum sheet once you get enough room.
                • 3400s10nos
                  • Sep 2011
                  • 8
                  im thinkin i may just make a tubular cross member and just get rid of the stock one . i was looking at my motor today and i dont think it would be that hard to mock up ..... but i may modify the pan to cuz i do have access to a tig welder
