Avg 3400/3500 hybrid engine oil temp?
  • Lunchbox
    Banned
    • Mar 2012
    • 16
    I installed a temp sensor in a thermostatic oil filer plate, what should it be?
    I might drill and tap the pan and put it there, what should the temp stay around there as well?
    And would it be bad to drill and tap the pan?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Average running temp should get to 190*F minimum. 230*F is still ok for engine operation. The max temp is 270*F but there should be a very good reason for getting the oil that hot. Racing would be one if them. But in any case a cooler should be used is that situation.
