3.1 motor mount
  • RWK
    • Jul 2004
    • 5
    3.1 motor mount
    Hi there,
    I have a '92 Corsica with a 3.1, anyone have any pics. of the top motor mount? My engine tilts when shifting between Forward and Reverse. It really moves. I replaced the Lower Engine mount Strut. Still doesn't seems right. If anyone knows where I can view some pics, that would cool. Tomorrow sometime I'll check on another Corsica in the dealership dead lot.
    Thanks
  • jmgtp
    • 1219
    Theres 2 motor mounts that I have found to be problematic in my L body. One is the upper transmission mount begins to sag with age and allows the transmission to bump the frame rails or the mount to 'knock' back and forth under load. Then theres the front engine support (if you look by the radiator cap you can see it) it is just an utter piece of shit (my L body is a 90, I don't think it changed for 92, tho I may be wrong). Even my brand new one allows an incredible amount of movement. I want to fill the gaps in the rubber with polyurathane. Sorry I have no pics (check out beretta.net may be some there).
    Good Luck
    -john
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
