Felpro 3400 "Problem Solver" gaskets
Tags: None
That's the first issue I've seen with those gaskets. I've ran them ever since they came out yrs ago, never an issue. Even when pulling motors apart afterwards, was always clean.
Possible defect in the material maybe?
Sent from my iPhone in some random spot of Texas.sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
I've never seen it happen around the intake ports but it did happen to my engine around a coolant passage, I actually still have that old intake gasket if you'd like a picture of it.
I don't know weather or not that was caused by me re-assembling though, I know I've always had problems with those gaskets laying flush with the cylinder head..... have to tweak them at times to get them to lay flat
1997 Chevy Lumina LS- SOLD
Mods:3400 cylinder heads, 01 upper & lower intake, 56mm throttle body, 22.5lbs injectors w/ 55psi regulator, 1' 3/8" thick radiator, tuned with lower fan temps by wot-tech
2010 Chevy Impala LT
Mods: LGD swap, 3.29 standard duty differential, 33 37 drive sprockets, Don Rome brackets, front and rear GMPP strut tower braces, GMPP 22mm front sway bar, GMPP 19mm rear sway bar and tune from Over Kill Motorsports
