fuel pressure
  • drayrunner
    • Feb 2007
    • 61
    fuel pressure
    can someone tell me how much pressure a unregulated fuel pump make for a 02 3100 Malibu. thanks
    unregulated? so basically maximum pump pressure possible?
    • drayrunner
      • Feb 2007
      • 61
      yes, that is correct, max pressure fron a factory pump.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        You can find out by putting a gauge on it and clamping a rubber part of the return line. I would guess around 70PSI. But remember this will put a big load on the motor and possibly stall the pump so don't make it a common practice.
        • js35
          • Jul 2012
          • 21
          Most fuel pumps I have "dead headed" as described above usually put out around 80-90psi, I believe there is a pressure relief built into the pump.
            i seem to remember reading something from GM stating around the 70 area before that valve is supposed to pop open....
            either way, the stock pump won't be putting out a whole lot of flow at that pressure.
