Cars stop while driving down the road, i know its the security system, but i don't know how to disable it, i.ve cut the yellow wire on the iginition switch, that didn't help, i read a little about a bypass ,does that work, and if so where can i get one.
malibu stops
cuting the yellow wire is the +12volt accessory wire?Originally posted by rayruner View PostCars stop while driving down the road, i know its the security system, but i don't know how to disable it, i.ve cut the yellow wire on the iginition switch, that didn't help, i read a little about a bypass ,does that work, and if so where can i get one.
I assume he's talking about the yellow wire for the PASSLOK system, which is the one that is the signal to the cluster/BCM to provide the proper resistance.Originally posted by packardbell View Postcuting the yellow wire is the +12volt accessory wire?
Also in GM vehicles, for many years the heavy yellow wire is the starter wire, the accessory has been orange or brown depending on which accessory you are talking about.
