does the 3500 cam position sensor work with a 3100 pcm?
cam position sensor?
"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."Tags: None
Yes, I've been running one on a 97 pcm since 08
ok, then mine is most likely bad, which helps to explain why I'm having idle problems to a degree. P0341 lit up while working on it today...Originally posted by 3400-95-Modified View PostYes, I've been running one on a 97 pcm since 08
looks like there's a wiring issue somewhere... damn..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Did you test from the ecm to the plug for continuity?
Originally posted by 3400-95-Modified View PostDid you test from the ecm to the plug for continuity?
not yet, going to probably tomorrow."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
