1987 s10 v6 swap
  • flyntone
    • Jul 2013
    • 8
    1987 s10 v6 swap
    howdy maybe this is the wrong motor to do this with but here it goes,, picked up a I believe 1987 (how can I tell) 2.8 I want to put it in a 1964 chevy van....... I wanna change to v belts and carb can this be done, can I use the same dist? also can I take off tpi and make a adaptor for a carb in its place thanks ahead of time
  • Ghosteh
    • Jun 2014
    • 131
    Yes, it can be done. I recently had a freshly rebuilt 2.8 with a Mallory distributor & Edelbrock manifold with a Holley, that was installed in my '53 Healey. It was never fully finished, and after reading the forums, I was corrupted enough by these guys to yank it out and install a 3.5L LX9. I sold the dist., manifold & carb a few months ago, but you should still be able to pick up all those pieces new, although they were a bit pricy.
    • Guest
      You can do all of that...
      You would be best finding a carb intake. The EFI dizzy could be used, but you would get no advance with it, unless you added something like a MegaJolt or retained an ECM.
      You would have to swap the entire front accessories, including the timing cover and the oil pan to match the timing cover. I personally like serpentine so much I've swapped into a few vehicles of mine now. It's far more reliable than any V-belt set-up I have ever used.
      • flyntone
        • Jul 2013
        • 8
        ok thanks for the response, think im going to sell complete package and go a different route............3.8 buick already carbed
          • 9187
          That should be our new slogan... corrupting enthusiasts for over 15 years!
