3100 Rebuild component questions
  • kill_them_all
    • Jul 2004
    • 96
    Anyone who has done a rebuild what type and brand of bearings (cam, rod, main) did you use?
    I am going to try and use moly rings if I can find some.
    Anyone had any experiance with sealed power and perfect circle products?
    Thanks.
  • TheProfessor
    • 869
    i thinik i used federal mogul frictionless bearings
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Frictionless hey? Where did you get thoes from? Must be some space age material I've never herd of :P
      • TheProfessor
        • 869
        no thats what they are called
        I Like V660s
        ~Jayme~
        • geoffinbc
          • 5831
          No they are not. They are called friction bearings. Not frictonless. There are anti friction bearings but they are either roller, ball or needle bearings. Friction bearings which are used all through todays engines are barings which rely only on a film of oil to operate. They are usually constructed of metals like babbit, tin, aluminum,bronze and copper. They are mixed together in modern bearings to form alloys in order to get the desired properties.
          • kill_them_all
            • Jul 2004
            • 96
            When I look at bearings they ask what size, 1-4 standard. How do I determine which type I need? Thanks.
            • geoffinbc
              • 5831
              Depends on machine work. If you need to align bore the block you need a bigger OD if you need to grind the crank you need a smaller ID. If you do both processes then you need both a larger OD and smaller ID.
              But if you do nothing to the engine then use standard bearing.
              • TheProfessor
                • 869
                oops my bad looks like im the now
                I Like V660s
                ~Jayme~
                • geoffinbc
                  • 5831
                  No worries
                  • kill_them_all
                    • Jul 2004
                    • 96
                    The engine does not need to be bored, I just need to get it honed, I do not see a standard bearing as an option on gmpartsdirect.com?
                    I am going for the stock rebuild, I am not sure what bearing material to use, I have a list of what they are out in my car.
                    I am going to use moly rings when I find them.
                    • geoffinbc
                      • 5831
                      Ok well if you do not touch the crank journals or the mains then buy all standard stuff. If you just hone the cylinders then you can still use standard rings. Wont be a problem.
                      • kill_them_all
                        • Jul 2004
                        • 96
                        I am going to polish the journals.
                        • geoffinbc
                          • 5831
                          Ok that should be fine. Just measure the sizes when done and make sure you are still in spec.
                          • kill_them_all
                            • Jul 2004
                            • 96
                            Should I replace the cams, crank, and knock sensors or are they fine?
                            • geoffinbc
                              • 5831
                              They should be just fine.
