TPS voltage
  • JohnyG
    • 32
    TPS voltage
    Hey Guys
    We are using mostly gm sensors for our formula sae car with the pe-ltd.com ecu. I still need a TPS however, we require one that shows 0V closed and 5V open. I was told all gm sensors were like that, however I would just like to have it confirmed.
    Thanks;
    -John
    14.9 @ 93.7MPH
    -Bonestock 3.4L
    -Bully Stage 2
    -2.5\" Exhaust
    -WAI
  • Juglenaut
    • 1130
    All they really are is a potentiometer, or similar to a rheostat.
    I am back
    Mechanical/Service Technican
      • 9191
      So to fully answer the question... if 5v is applied to the sensor, it will read 0v shut and ~5v when open.
      • JohnyG
        • 32
        Great, thanks guys.
        -John
        14.9 @ 93.7MPH
        -Bonestock 3.4L
        -Bully Stage 2
        -2.5\" Exhaust
        -WAI
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Voltage will depend on your refrence signal. But yes all GM sensor/systems have and still use a 5V refrence.
          Now I have never checked a TPS so I am not sure if it actually will go from 0% to 100%. If I get a change I have one off my truck and could test it.
          • RidgeRunner
            • 971
            I thought it went from .5v to 5v.
            60v6's original Jon M.
              • 9191
              The way it mounts on the shaft only allows it to go down to ~0.5V, but the potentiometer itself will go all the way down to 0v.
              • geoffinbc
                • 5831
                Ok there ya go. Will it also go fulley closed?
