quest about engine temp
  • geldartb
    The Situation
    • May 2004
    • 1994
    ok anyone with a 3100 when you drive around in temps between 30-50 how far up does your temp gauge go up mine doesnt even hit 1/4 but i still got heat and dont smell antifreeze. also would putting cardboard infront of my radiator be harmful in anyway cause i do know it makes it stay warmer than without it tryed it once for 5 minutes. could this be a coolant issue or a heater core problem where its running cool. even idling for 20 minutes the temp didnt even hit 1/4 but it was cold that night though. summertime too the most it went up was halfway then the fan kicked on this was in city driving dont do much of that. any help is appreciated
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • korbendallas68
    • 3400swap.com •
    • 553
    Sounds like the thermostat.
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Yea I agree. It should operate just a bit below half way.
      • geldartb
        The Situation
        • May 2004
        • 1994
        damn guess its time to change that before it goes when its really col or im far away from home. might as well do a flush while im at it too get all the crap out of there. had the cardboard in fronnt of the ac condensor brought it up to a quarter on light driving for the cruise around 40-50 just below a quarter.
        99 Grand Am GT
        • geldartb
          The Situation
          • May 2004
          • 1994
          would anyone possibly have the part number for the 180 tstat for the 95 3100 and should i replace the coolant temp sensor while im at it
          99 Grand Am GT
          • acascianelli
            • Oct 2004
            • 24
            mine does the exact same thing, barely heats up to the 1/4 way mark. my guess is its the thermostat stuck open. ive been planning on changing it for a while but i dont know how to get the thermostat housing off cause the bottom bolt is in a hard place to get to. look at yours and youll see what im talking about, i really dont want to try to remove my crossover pipe to change it. some people say if you remove the TB it is accessible but i guess i will find out this weekend.
            1994 Pontiac Grand Prix 3.1L
            • geldartb
              The Situation
              • May 2004
              • 1994
              thats part of the reason why i havent done it. ive been saying i need to change the thermostat since last january but it hasnt given me any problems so i left it alone. im all set with takeing the crossover pipe off ill try the throttle body way and let you know how it works out. ill be doing it either tonight or tomorow morning.
              99 Grand Am GT
              • geoffinbc
                • 5831
                You dont need to take the crossover off. You just need an open end wrench and take your time. Did the same thing to my moms 1994 3100 and it took about 1 hour.
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  i was trying to find a way to do it without removing that thos bolts for the crossover are probably rusted to hell. i took a peek at the junkyard while i was there and you are right with the open ended wrench i did seem easy a pain but easy. got all the stuff gonna give it a try tomorow
                  99 Grand Am GT
                  • korbendallas68
                    • 3400swap.com •
                    • 553
                    That's the part number for the thermostat.
                    1995 Grand Am GT
                    www.3400swap.com
