distributor types?
  • wet_buffalo
    • 11
    distributor types?
    Is there a difference between a TPI controlled distributor and
    a TBI controlled one ?
    I have a 88 fiero that I'm installing a k&f blower on
    I was thinking of replacing the ecm with a TBI ecm(s-10 v6)
    make a new harness tap the old sensors and use a TBI
    seems a nice way to go and still keep my emissions
    plus I pick up a knock sensor input
    any thoughts?
    another fiero fool
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Um why? MPFI is a much better system. Oh and you do not have TPI injection (as in the ones like the camaro) But to answer your question the distributor is the same.
    • wet_buffalo
      • 11
      its a lot easier to install a tbi than fabricate from scratch a TPI style injection for a blower
      plus i get a knock sensor which is huge plus if yer boosting
      I looked under the hood of an 88 s-10 last night and got all my answers
      thanks for the reply wish me luck
      another fiero fool
      • geoffinbc
        • 5831
        What blower are you using? The Fageol, B&M or a Centrifugal type?
          • 9191
          He said a K&F, but I've never heard of it...
          • geoffinbc
            • 5831
            Ok yea never herd of it.
            But I can tell you now that using a TBI with any blow through type of forced induction is a big no no unless you contain the TBI in a sealed box like they used to do with carbs.
            • wet_buffalo
              • 11
              k&f was fageols old name
              thats how I found it on ebay, the unit was rebuilt and came with the intake
              I have 4 inches of clearance on top of the blower for something?? before I cut the hood
              I was thinking of horzontally mounting 4 TPI injectors and using a late eighties tpi(camero) throttle body
              since the fiero injectors are batch fired the injector #s just has to be even
              but it seems that an 88 s-10 TBI ecm uses the almost same pin out as my ecm so.. swap ecms and add a 4.3 TBI on top might be easier gotta go measure a TBI this morning to check clearance
              another fiero fool
