Jimmy Digital Dash Cluster Repair..
  • wireman121
    • 29
    I know the digital dashes in the Jimmy/Blazer/Bravada have a problem where they stop working. Well, my Jimmy's dash stopped working. Everything is dark except for the middle mileage portion. All of the voltage/fuel/tach/oil/temp guages are dark. Has anyone else had this problem, or know how to repair it? before I send it out for $200 repair
  • Rhedalert
    Dr. Feelgood
    • 1574
    I can only assume the only way to attempt a repair is to resolder all the points on the circuit boards, especially around the various chips. It can be done by someone with a steady hand
    Brian
    3400 SFI V6, 4T60e
    • wireman121
      • 29
      Just to update. Before I was spending $200 on sending the dash out to be repaired, I tried fixing it myself first. Turns out the sub-circuit board that was supposed to be mounted and soldered to the dash circuit board was just pressed into the holes. Maybe the solder flaked off or something, but anyway, I resoldered the whole board, and the board back on and everything works perfect!
      • Rhedalert
        Dr. Feelgood
        • 1574
        glad you got it working! It's usually a problem with solder points when delco electronics fail, luckily not much else happens
        Brian
        3400 SFI V6, 4T60e
        • Cliff8928
          • 532
          Hmm... I wonder if that fix will work for my digital in my beretta.... It currently is all flaked out with bars displaying in the middle of the gauges only....
          but it's made by VDO... so that might change things..
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          Cliff Scott
          89 BerettaGT
          04 AleroGX
