piston ring orientation
  • Froggx
    • Jul 2004
    • 385
    I forgot to look when I took them out, and didn't think about it when I first dropped them in, but while I still have easy access to them, is there a specific way the pistong rings on the 3400 are supposed to be aligned when you drop the pistons in the block?
  • sharkey
    • Jun 2004
    • 2061
    RE: piston ring orientation
    nothing real specail, just make sure the gaps are not lined up. i like to have the compression ring gaps 180 degrees from each other, and make sure the oil ring gaps are not lined up.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      YES!
      Very important. However I just looked on GM's site and cannot find a thing.
      • Froggx
        • Jul 2004
        • 385
        Originally posted by betterthanyou
        YES!
        yeah this is my problem, I can't find snap about it
        • geoffinbc
          • 5831
          Well I know I have it at home for my old 2.8L
          I will try and remember to post it
          • RacerX11
            • 1060
            Here is a PDF from JE Pistons that shows the gap orientation on the 2nd page: http://www.jepistons.com/pdf/piston_instrc4032.pdf
            This orientation matches what is in my GM factory service manual.
            Marty
            '99 Z-28 - Weekend Driver
            '84 X-11 - Time and Money Pit
            Quote of the week:
            Originally posted by Aaron
            • kill_them_all
              • Jul 2004
              • 96
              180º from each other and do not place the gaps on the major thrust faces.
              • Synestral
                • Mar 2005
                • 53
                According to that PDF, the gaps are on the thrust surfaces.
                92 Lumina Z34
                Found coolant in the oil and metal in the filter.
                Also found a home in the engine compartment for a turbo and intercooler
                Some pics at CarDomain
                • RacerX11
                  • 1060
                  Yes they are. Don't listen to kill_them_all; Go by the PDF diagram...it matches the service manual.
                  Marty
                  Quote of the week:
                  • Froggx
                    • Jul 2004
                    • 385
                    I dug up a service manual, it agrees.
                    edit: my service manual said to install the inverse direction for the other cylinder banks so that like oil ring expender gaps face each other and such, should this be followed?
                    • oleman
                      • Apr 2005
                      • 40
                      I just pulled 6 pistons from a 3100. Non of the piston rings were lined up properly.
                      The simple reason is because the rings rotate around the piston during operation.
                      All the gaps probably pass other many time in a few hours of running.
                      Line them up correctly at install and then forget about them!!!!
