Changes from 95 intake to 2000 intake
  • jweir22
    • 111
    Hi im just trying to refresh my memory on what needs to be done to the new style 2000+ intakes to fit with a 95 setup.
    1:Tap out heater coolant hole to fit 95 thread
    2:I think the lower intake already is ground down for the rocker clearance
    3:I think 2000 had a crank case vent behind the throttle body on the top of the upper plenum that i have to plug cause i have a small filter on it now.
    Anything else let me know.
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
  • jweir22
    • 111
    I guess nobody knows so ill tell ya what i have to change.
    Cold Air K&N Filter
    58mm TB
    • v6h.o.
      • 1418
      i think you have it pretty much summed up right there, thats why no-one has responded.
      i cant think of anything else at the moment right now.
      Colin
      • jweir22
        • 111
        OKay good i thought maybe i stunk or something.
        Cold Air K&N Filter
        58mm TB
        • v6h.o.
          • 1418
          dont forget to get the proper gaskets for the new 3400 intake, to take advantage of the 3400 taller intake ports, get the 3400 gaskets.
          Colin
          • v6h.o.
            • 1418
            hey Jweir22, found a solution for the upper intake EGR mounting problem:
            As some of you know, I made an adapter plate for the 2000+ intake manifolds. While making it, I took some pics, but unfortunately I forgot to take any during some of the steps, so I'll have to explain the best I can. I made a plate that is 1 inch thick. It cannot be any thinner, as the hose...
            Colin
            • jweir22
              • 111
              Thanks i was thinking of something like that i have to take a look at my EGR.I think i'll make it look sweet so it looks professional, i'll make one and show some picks and maybe i could make some foer people that don't have access to a machine shop.
              Cold Air K&N Filter
              58mm TB
              • jweir22
                • 111
                Wouldn't it be even easier if i just bought a 2000+ EGR valve wouldn't it just bolt on?
                Cold Air K&N Filter
                58mm TB
                  • 9191
                  It would probably bolt on, but the electrical connection I'm almost sure is different. And, EGRs usually run $100+, so the price difference is pretty big.
                  • jweir22
                    • 111
                    Well i found one for 35 bucks how can i tell if the connection is the same before i buy it? Does anyone have a 2000+ EGR Valve that can check and see what the connection looks like? That would be great if some one had one.
                    Cold Air K&N Filter
                    58mm TB
                    • jweir22
                      • 111
                      Better yet if its 3 wires could'nt you just trade connectors and wire it up.
                      Cold Air K&N Filter
                      58mm TB
                      • jweir22
                        • 111
                        Anybody know the difference form a digital or a linear EGR?
                        Cold Air K&N Filter
                        58mm TB
                        • StudlyCamaro
                          • Nov 2003
                          • 692
                          digital EGR valves are very expensive... the digital one for my car was over 200$... gurrrr
                          3.4L camaro some goodies
                          • jweir22
                            • 111
                            The egr for the 2000+ has 4 pins does anybody know how many pins a 95 3100 egr has get back to me.Just would like to buy one and bolt it on with no plates to make.
                            Cold Air K&N Filter
                            58mm TB
                            • Manitcor
                              • 573
                              the 2000+ EGR willnot work, there are 3 wires for a 95 egr and 4 on the 00+. I had an adapter plate made for mine and it works great, and I didnt have to hack into my wiring harness.
                              Mine is kinda basic looking as I made it from some scrap steel laying around. I would love to see a billet alunimum one.
                              You will of course need EGR gaskets for both EGRs and longer bolts to hold it on.
                              1995 Monte Carlo LS
                              3400 SFI 60v6
