Just double checking that 95 3100 fuel rail and injectors will fit in a 2000 3100 intake.
95 fuel rails in a 2000 intake
Yeah, it will fit. I have a 94 rail on a 00 lower manifold.-Brad-
When your rail is out is there anyway you can check the fuel injectors to see if there spraying properly?1995 Cutlass Supreme 3100 SFI
Cold Air K&N Filter
58mm TB
Dynomax Duel Exhaust with Performance Catalytic Converter
FFP Underdrive Crank Pulley
1/4 mile 15.65 at 90.8 mph
well after u do a swap of thwe intakes before u start the car just turn the key to see if its leaking or not other than that I'm not too sure
1996 Monte Carlo LS 3100 engine, 1/4 16.131 *RIP
88 cuttlass supreme 2.8L coupe
90 dodge daytona 3.0 v6
