Oil Temp Gauge - Mechanical fitting
  • Jim Gunther
    • 13
    I intended to utilize an Auto Meter Oil Temp gauge (Mechanical) on my www.StalkerV6.com but, the thread pattern of the hole on the left side of the oil pan (current low level indicator probe???) seems just a bit off.
    The Auto Meter fitting is 1/2" NPT - Does anyone know the diameter/thread of that existing hole. I'd like to avoid welding in a new bung.
    TIA, Jim
    Be well,
    Jim Gunther
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    It is not any form on NTP thread because it has no taper. If you look you will see it uses a gasket.
    It is a 3/4 threaded hole and apears to be course thread. But I dont have any thread guages here to check.
    • Jim Gunther
      • 13
      That was quick, better.
      Any chance it might be some weird but close metric size?
      BTW: Is that probe for low oil sensor?
      Thanks, Jim
      Be well,
      Jim Gunther
      • geoffinbc
        • 5831
        It could be metric.
        And in actual fact it is not 3/4" thats too small. But 13/16 is too big.
        Take it to a hardware store and find out.
        • GordSipko
          • Jan 2004
          • 11
          60Deg hardware is all metric!
          The Oil Level sensor thread is either a 20 or 22mm coarse pitch thread. I made a bung for the pan in my truck and had some pieces left over but cannot find them today to measure...
          \'83 S10, 3.4 SFI, 4L60E
          • geoffinbc
            • 5831
            Then why is there NPT threads for the coolant drain holes and sensor holes? Thats not metric :P
            Buy yea I know everything else is.
            • Jim Gunther
              • 13
              Metric/NPT?
              That's the funny thing. I actually installed the Auto Meter supplied probe (BEFORE I GOT THE MOTOR RUNNING) and THOUGHT it fit O.K.
              My mechanic (who got it running and did some other back-up work) removed the probe and fitting saying "It would leak" though neither of us actually saw it leak. He DID say there was a thread mis-match but, IT MUST BE CLOSE. I didn't force it.
              Meantime, I've sent a note to Auto-Meter - I can't imagine they've never had this issue before.
              In any event, I'll post whatever cure I discover.
              Be well,
              Jim Gunther
              • Jim Gunther
                • 13
                Promised I'd post Auto Meter's response. I don't think it's responsive:
                >>>>>The Auto Meter supplied nut is 1/2"NPT (NPT measures larger than its
                corresponding size). I am sorry, but we do not offer a adapter that
                large. You may want to try using a sandwich adapter from earls fittings
                that goes between the oil filter and engine block. You will plug one
                3/8"npt port and use the other for your oil temp gauge. Contact Earls at
                www.earlsplumbing.com and confirm that plugging off the ports on the
                sandwich adapter will not hurt oil flow through the filter when the
                sandwich adapter is used.
                Thank you.<<<<<<
                Be well,
                Jim Gunther
                • Doubt_Incarnate
                  I still watch ROBOTECH!
                  • Jan 2005
                  • 1130
                  sounds like they know alot about earls... they must do alot of "re-directting" instead of solving.
