Heads
  • gocatsgo
    • Jun 2005
    • 8
    Heads
    Can the heads on the rwd 2.8 3.1 and 3.4 engines to on either side or do they have to be on a particular side?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Take a look at any V engine (excluding some DOHC motors) every head is cast the same. Saves money and you never have to worry about L or R
    • ceecpa
      • Aug 2005
      • 2
      Heads interchangable?
      Does this mean that 2.8L cast-iron heads can be used on the 3.4L RWD motors?
      Can a distributor be used with the 3.4L motors?
      Thanks.
      • sharkey
        • Jun 2004
        • 2061
        RE: Heads interchangable?
        yes and yes, however you cant use the 3.4l rwd sfi intake, as it would interfere with the distributor.
        • ceecpa
          • Aug 2005
          • 2
          Thanks and Re-cap
          Thanks for the help. Here's the summary of my plan:
          1. Use 3.4L rwd motor;
          2. Use 2.8L heads, intake, and distributor;
          3. Use appropriate carburetor (don't yet know what that will be - probably OEM.)
          I'm going to install the engine and 5-speed manual transmission into an MGB. It seems to produce a powerful, well-balanced car.
          Thanks again.
