3400 Horsepower rating
  • KNTRDR
    • Aug 2005
    • 14
    Here's one that I've been scratching my head over. My 1996 Lumina APV with the 3400SFI engine is listed to have 180HP. However the later 3400s such as used in the 1998-up Ventures, Aleros, etc. all seem to show as having 185HP, even though they appear to be the same engine. Anyone know what the change in power is caused by?
    Adam
  • gboogie99
    they still can't catch me
    • Nov 2005
    • 348
    different flow on the intake manifolds, it was a minor revision by GM that added the HP. Also head are slightly different.
      • 9183
      All 3400 heads (96-02) are the same, so I'd have to shoot you down on that one. I will agree with the flow through the plenum though, as the plenum internals changed slightly over the years. There have also been revisions to the exhaust manifolds over the years that could cause the slight increase. And finally, it could easily have to do with PCM programming changes.
      • TheProfessor
        • 869
        im leaning heavily towards a change in the PCM
        I Like V660s
        Does Chevy make beer
        ~Jayme~
        • gboogie99
          • Nov 2005
          • 348
          correct me if I am wrong but doesnt the 3400 flow a considerable amount more air than the 3100 which also causes a difference in horsepower although it is practically the same engine?
          • GutlessSupreme
            • Nov 2004
            • 166
            The 3400 has a larger bore than the 3100.. besides that yea they're pratically the same engine. Up until I believe '00, the 3400 had larger-port intakes and heads. After '00, 3100s started recieving heads/intakes with the same big ports the 3400s have.
            -Tony | gtsdurango.net
            '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
            '90 Turbo Grand Prix STE - ehh.. I'm working on it.
            '92 Gutless Supreme SL - RIP 5.2010
            '90 Turbo Grand Prix - RIP 6.15.2005
            • Syn
              The Master Piece
              • Oct 2005
              • 599
              QTF!
              00+ 3100 is the same as the 3400 top end
