Problem with accelaration.....
  • EspanolaGuitarista
    Visionary
    • Feb 2004
    • 254
    I have a a misfire during low rpm if I am accelarating. Not detonation, just a miss. My plug wires need to be replaced since I cut through the shielding on a few of them and the plugs need to be checked. It also seems to do it in the same exact place every time I accelarate. Could this be a dead spot in my TPS?
  • Rhedalert
    Dr. Feelgood
    • 1574
    the wires are damaged you say? I'd start with that.
    Brian
    3400 SFI V6, 4T60e
      Yeah if you know your wires are bad that's the first thing to do then see if you still have a problem. 99% garuenteed it's that. Bad wires will cause miss fires. Fix all your known problems before trying to diagnoise other ones.
      Put new wires & plugs and report back!
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Check under your hood in the dark. If you cut the shielding on your wires, you should see a pretty light show.
        • prophiseer
          Blaspheming Heretic
          • Jun 2006
          • 354
          If you can't wait till dark you can also take a spray bottle with some water in it and spray a mist over the engine. You know, the 4th is coming up, gotta celebrate!
          N-body enthusiast:
          {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
          {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
          Current Project:
          {'90 Chevrolet C1500 Sport 350TBI}
            Visionary
            • Feb 2004
            • 254
            problem fixed...
            It was the wires shorting to ground I'm sure.
            Installed new rotors and pads today. Cost me 80.00 plus a few other items.
            Question:
            Does anyone know off hand the metric # for the bolt that holds the lower engine mounts? There are two bolts. I'm missing the one that goes on the upper part next to the crank pulley. I'm guessing M8 or something close.
            • Rhedalert
              Dr. Feelgood
              • 1574
              they're bigger than an M8, I want to say M10 but I'm not sure. I know they're a high strength grade.
              Brian
              3400 SFI V6, 4T60e
              • robby1870
                Squaddoosh
                • 584
                M10 sounds right, but I havent taken off a lower mount in over a year. Probably an 8.8 or 10.9 grade.
                Robby Whitesell
                2006 Pontiac G6 GT
                1985 Toyota Pickup DLX
