Down Pipe
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Down Pipe
    Does anyone have a place in mind where I can buy custom (TGP) T25 exhaust flanges? I would prefer of one without the 90* (?) bend. The stock one is just too much work for what its worth to make it into something I would want.
    I am referring to the turbo downpipe flange.
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Flanges
    If you or you know of someone that can fab up some, don't be affraid to post!
    • Guest
      ATP-turbo.com
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        I already looked there and I did not see anything that'd assure me it'd fit the stock TGP turbo.
        • sharkey
          • Jun 2004
          • 2061
          your t25 turbo has a t25 exaust section. any t25 flange should work.
          • Syn
            The Master Piece
            • Oct 2005
            • 599
            x2 with sharkey, i'd just make a nice cut on the tgp's down pipe and use its flange. i haven't looked at a tgp d/p in awhile so idk how much room is there
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              I would try it, but like Syn said I don't even have the stock parts to alter.
              "your t25 turbo has a t25 exaust section." I don't want the divorced type flange.
              I did however once buy a "T2" flange, but once I got it and went to go fit it up to the garrett it didn't match up.
              Here is a couple pics of what I have:
              It doesn't fit.
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                This the right one? I'd prefer just a single hole.
                Would I even need to utilize that hole? I really dont see anything higher than 10PSI coming from the T25.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Besides the amount of exhaust holes, what would be the difference in these two?
                  Here's the turbo with and without the current suppose T25 flange on it.
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    ur blocking the wastegate flap lol
                    plus that doesn't cover the end of the turbo on the right side completely
                    even if it did you'd have to run a external w/g
                    word of advice u'll need a flang with 2 holes
                    because i think theres not enough room for the w/g to open but i could be wrong its been awhile as i said
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      So I got an email from atp saying that this one:
                      should work.
                      We'll see.
                      • Syn
                        The Master Piece
                        • Oct 2005
                        • 599
                        thats it!
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          I finally received that flange from ATP a couple a days ago...
                          Well, it doesn't fit the profile of the turbocharger although the bolt pattern fits fine. I was disappointed about this so I emailed ATP about it and they are willing to work with me on making the correct flanges for the Garrett T25 Turbocharger (Grand Prix) . I am pleased that they are doing this for me. So they then asked if I knew anyone that would have interest in this "redesigned" flange... Well is there? Speak up if you're looking for this type of flange.
