oil filter thread issue
  • bonecrrusher
    • 79
    My 3400 block came out of a 99 Venture minivan that has the crappy radiator oil cooler on it, I've removed the oil cooler, and want to put a 3100/3400 Beretta style Oil filter neck on it. Now heres my question, since the oil cooler setup had a threaded bolt on it that screws into the block and the oil filter, can I get a threaded oil filter bolt that will allow me to put the filter right on the 3400 block? Does anyone have a part number for a replacement oil filter threaded bolt?
    Thanks,
    Craig
  • bonecrrusher
    • 79
    Brad helped me out, thanks man!
    • Guest
      care to share with everyone else?
        • 9191
        I had a spare that I was willing to send to him... I'll see if I can't dig up a PN though.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          The double threded nipple is screwed into the end of the oil filter adaptor. The bolt used is also a very common part.
          If you take the ipple out of the adaptor and thread it into the block then you can put your filter right on the block.
          • GinoBeats
            • Mar 2005
            • 145
            #466383 is the part number for the fitting
            http://www.v6z24.com/registry/ginobeats/
            http://www.v6z24.com/registry/ginobeats/2
