Puffs black when cold
  • torq455
    If I only had money!!!
    • 1615
    Ok, I recently put a 62mm TB on. Idle relearned and ran great except for that pesky off idle hesitation got worse. For the hell of it, I adjusted the idle set screw to open the blade a tad. Redid the idle relearn...ran great with virtually no more hesitation!! Much better than stock. A few starts later it now puffs black out the muffler for about 30-40 secs then clears out. It does this ONLY after sitting 8 or more hours when the temp outside is 55 degrees or colder. 60 or warmer, it seems like it wants to run rich and chug but dosen't. I have tried putting the idle setting back where it was, disconected the batt, and idle relearned again. Still have the cold rich prob. Changed MAP and checked vac lines. No change. Discovered my cruise control quit working too--related? I hate to wash the cylinders down with gas on a cold start. I ask what the hell?!!! I could just put up with it, but I know something's not right and I can't live with it. Thanks guys!
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    o2 sensor took a dive? Try putting the stock TB back on?
    • d.o.h.c
      • Jun 2004
      • 981
      I am having the same problem with my 97 sunfire. I put exhaust on it and ever since I can stand it. I have to clean the tips every 2 days. I changed the plugs and there are no wire. Maybe the pcv. I am not sure. also it has a slight hesitation in first gear.
      • torq455
        • 1615
        02 is fast and very responsive. it did run fine with the bigger TB.
        Andy
        • d.o.h.c
          • Jun 2004
          • 981
          i also did my o2 sensor and no luck
          • torq455
            • 1615
            looked at a plug and it's nice and black. lightly sooted, it's been idleing alot so i'll have to blow it out and recheck.
            Andy
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              Is your fan constantly on? check the coolant temp plug.
              This is an odd problem.
              No DTC's?
              • torq455
                • 1615
                nope, comes one when it's programed to. no codes. you're tellin me! if ya'll wanna IM me i'm at torq455 on AOL.
                Andy
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Are you using you stock sensors in your new tb? If not, maybe try that?
                  • torq455
                    • 1615
                    yep and those are all good.
                    EDIT:: it's torq455p
                    Andy
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      So when you did this you MADE SURE you didn't bump the fuel regulator's vacuum line off or anything like that, right?
                      Just checking.
                      • torq455
                        • 1615
                        thought about that too. checked at the TB-- those 3 lines...the 2 smaller ones held vacuum. i know the other is for the CCP. what would happen if the diaphram in the fuel regulator were to blow? although i have 36#'s at idle...
                        Andy
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          It would leak out into that vacuum line.
                          • torq455
                            • 1615
                            may have to double check that.
                            Andy
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              Oh and that would cause you to run rich since it cannot regulate properly.
