rattle from engine maybe. timing question
  • jeff89fbird
    • Nov 2006
    • 42
    I've had a rattle for the last couple weeks. Occurs from 1500 to 1700 rpms under light to medium loads. Won't do it while in neutral. It has a sort of pulsating frequency to it that slows the higher the rpms get until it goes away. Like something that is spinning and rattling. Kinda hard to describe.
    It's a brand new 3.4. The cam is a stock size replacement from comp-cams and has a 4 degree advance grind. Would that 4 degrees cause my timing to be too far advanced when I set it at 10?
    I can't get ahold of the manufacturer today, but I'm tempted to go out and retard my timing a bit to see if that makes a difference.
  • jeff89fbird
    • Nov 2006
    • 42
    I changed the base timing to 6-7 and it still rattles. I guess that rules out spark knock.
    It seems like it's coming from the right side of the engine when I center my head over the console while driving.
    • 91z24build
      • Dec 2006
      • 65
      Sounds like a worn timing chain or gears to me. Try using a timing light to see if its fluctuating.
      • 86euro
        • Dec 2006
        • 219
        Might want to check the torque convertor bolts, or it could be the TC itself.
        -It is an auto, right?
        • jeff89fbird
          • Nov 2006
          • 42
          Yep it's an auto. My SES light is coming on again too. I'm betting all I'll find is a code 13 again. I'm having it hooked up to a scanner next week and maybe find out if something is screwy. ( I know something is screwy actually, but what?)
